97 Grand Cherokee Limited issues
I am the proud "new" owner of a 97 Grand Cherokee Limited 4.0 4x4 Automatic I believe it is a ZJ???. She's got around 154,000 on her but she is in good shape, now I have a whole new "world" of vehicle to learn.
Here are my first troubles, I am getting the "coolant sensor bad" error, (which I think I already have the solution to, going to check the connections to the VIC ) and driving it today I got my first code if I am remebering right it was a P0783 3-4 shift ( I know the text part is right "3-4 shift" but I might be wrong on the actual code #) any ideas why????
Re: 97 Grand Caravan Limited issues
Yes it is a ZJ.
As for the "COOLANT SENSOR BAD" message, it could be a bad COOLANT LEVEL SENSOR in the overflow bottle or broken wire at the VIC. I had this message on my new ZJ and replaced the sensor in the bottle and did not help, I then tore the VIC out and checked the wires (Pink/Black wire for the coolant level sensor) but could not find any that looked bad. So I soldered a 3.2K resistor across the terminals of the plug and the light didn't come on so I checked the resistance on the sensor and it read about 3.2K, So I melted the solder and remove the resistor then plugged the sensor in and haven't had the message since then, that was about 2 weeks ago. I think the plug wasn't making good conatact and caused the message, so with the lil bit of solder still in the plug it helped make good contact. Code P0783 - 3-4 shift solenoid, No rpm drop @ 3-4 shift. The ratio of engine rpm/output shaft speed did not change beyond the minimum required.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust). W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
I honostly couldn't tell what that code would pop up for, I have never experienced that code or even seen that code, you might want to try a google search, or even try to search the forum, for tha code and see what you can find.
Re: 97 Grand Cherokee Limited issues
Well the coolant sensor was a faulty connection on the back of the VIC, I cleaned it put some dielectric grease on the conacts and all is/was working right.
I put it all back together, then I drove the truck about 20 miles and on the trip the VIC just went blank??? It shows no info at all now, if I press any button it flashes the time & date around 11 times and then goes blank again. This Jeep is starting to live up to J-ust E-xpect E-very P-roblem and I haven't even owned it a week yet. Before it would beep at me and tell me I had a "bad coolant sensor" 30 minutes of looking at a VIC showing nothing wrong and POOF now it is blank, at least before it worked LOL. Any Ideas what has happened now, it shows no diagnostic codes. It is kind of disturbing that when I google this problem, I only get MY posts. Uh-OH I can't be the only one this has happened to??? Last edited by rattler02; 07-26-2007 at 11:08 PM. |
Anyone got a diagram/schematic for the plug on the VIC to say what wires do what???
Thanks, it tuned out to be the #6 fuse after all. Replaced it and all is well.
To fix the connection at the VIC do you have to take it out from the inside or is there a computer on the firewall some where?
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
Thanks, problem solved. I think this should be a sticky b/c its a common problem.
