Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-22-2007, 10:19 PM
TeamOK TeamOK is offline
Speedometer needle osillates at zero when turning on or off ignition
This is a 99 SC1 and when the ignition is first turned on or off the speedometer needle , being on zero miles per hour , will oscillate/vibrate on the 0 miles per hour part of the speedometer for about 5 seconds then quit . Is there an external sensor to check on or is this a pull the dash to look for a loose ground type of problem ? It is not causing any driveability problems but just an annoyance . My hanes manual schematics are hard to follow . I can live without fixing this problem if it means pulling the dash .
Old 04-20-2008, 07:47 PM
zzdaddyo zzdaddyo is offline
Re: Speedometer needle osillates at zero when turning on or off ignition
I have the same issue, does anyone know what the problem is? can it be fixed easily?
Thanks
Old 04-21-2008, 11:59 AM
RC1488 RC1488 is offline
The Speedometer is controlled by the PCM which gets information about the vehicle speed from the Vehicle Speed Sensor on the rear of the transaxle. You may want to make sure the connector is plugged in all the way, or using a scan tool, see if when moving the scanner tells you a speed. If it does then the speedometer gear may be broken and removal of the cluster would be needed
Old 04-23-2008, 05:30 PM
The speedometer and tackometer both work fine when the engine is running and driving. The osillating only occurs right after the ignition is turned off. It will also occur when turning the ignition switch on, but not starting the engine.. it will stop after about 5 seconds. So, it does work, it's just annoying. Thanks for the reply, but do you still think it could be a broken gear? Could an electrical component be failing?
Old 04-23-2008, 08:43 PM
If it works for normal driving, then i dont suspect a broken gear. However ask to what exactly im not sure. Your the first ive ever read have this problem
Old 04-23-2008, 08:45 PM
If the speedometer works fine when driving, i dont suspect a gear being the issue. however what the problem is exactly im not sure. Your the first ive read have this issue. Sorry
Old 04-23-2008, 09:45 PM
Thanks RC. There were a couple other posts with the same problem, (inlcuding this orignal post from TeamOK) but no responses... maybe someone else has come across this problem that could respond. Thanks again.
Old 04-27-2008, 07:10 AM
more info... I have an aftermarket remote start kit installed, could that be causing this issue? also, to clarify, I have a 99 SL2, not a 99 SC1 like TeamOK. Thanks.
Old 04-27-2008, 08:43 PM
tvsteve tvsteve is offline
This action is normal for the 99 year. My wagon, purchased new has done this from day 1. I questioned Saturn back in 99 on this. Jitter lasts for 5 seconds. I replied to this problem over at Saturnfans as other 99 owners have the same issue. BTW there are no gears, it's all electronic.
Steve
Old 04-29-2008, 11:24 AM
Not entirely true. There is no mechanical linkage from the tranny to the speedomoter, but there is an electric motor or servo that moves the needle based on the electric signal from the PCM.
Old 05-09-2008, 04:00 PM
Steve
Thanks tv.. so nothing to worry about?, just a "feature"? It's annoying, but I guess I can live with it. Thanks again. zz.
Old 06-13-2008, 10:52 PM
Trikeman72 Trikeman72 is offline
Send a message via Yahoo to Trikeman72
i just got a 99 sc1 coupe and it does the same thing.. i was wondering what that was about lol...
problem i have it blowin frikin turn signal fuses sighs
Old 10-01-2008, 12:55 AM
Albanianmafie Albanianmafie is offline
I have the same problem on my 99 sc2. the damn thing is annoying thats for sure.i pulled out the dash board unpluged and cleaned both fuses in the back but it still does that.
