Old 07-22-2007, 09:57 PM
bboytek bboytek is offline
I've got a warning light problem
One of the lights switched on, it looks roughly like like a little rectangle with a line going through the top, located in the top left of the dashboard with the rest of the warning lights, to the left of the RPM and speed meter.
I don't have the manual, and I can't find it online either, so I'm in a bit of a situation. I thought it might be the coolant, but I just put some in and it's still on.
Can anybody help me?
Old 07-23-2007, 04:00 PM
alejmr alejmr is offline
Re: I've got a warning light problem
Ok seems to be you're a victim of coolant consumption because an UIM failure, what model do you own?
Old 07-23-2007, 04:50 PM
'98.
I solved it by adding EVEN more coolant, and then taking it to a parking lot and revving the engine until it was force to use coolant. Guess simply turning the car on and checking the warning lights isn't enough.
For everybody else, what's a UIM?
Old 07-23-2007, 05:02 PM
Upper Intake Manifold, it'a a known problem for the 3.8 intrigues, if your car is "drinking" coolant at least once a week you might want to change it as well as the lower intake gaskets, with simple tools and a bit of patience, you can DIY, even if there's no consumption as a preventive maintenace so you are no left on the road (personal experience) you migh want to check this link:http://www.automotiveforums.com/vbul...d.php?t=701325
