High idle, other problems
When I start my car up it idles up very high for a second, a lot higher than it used to, then it goes down. Sometimes it will continue revving up and down slightly for a little while before it settles down. Now recently I've noticed that if I park the car while idling it will climb past 200 degrees. It gets about halfway between the 200 and 260 marks. Then when I drive it will drop down to 200 again. Any ideas at what my problem could be?
Re: High idle, other problems
2002 Light Pewter Metallic Formula A4: Cold Air Intake with sealed MTI Airlid, ported and polished TB, smooth bellows |
Well zr440 what year and engine do you have ???????
Sounds like a cooling system problem on the temp issue. On the high idle, check for vacum leaks. Also check your IAC as this controls idle. hope that helps.
1999 Grand Am SS 3.4 OHV
