Old 07-22-2007, 03:36 PM
stevenoble's Avatar
Kawasaki ZX12R Ninja
I made a start on the Tamiya Kawasaki ZX12R Ninja at the beginning of the week.After enjoying the Suzuki Hayabusa build so much I decided to stick with two wheels for a while at least.Here's a few progress photos of the build so far.
The engine
All the body parts are painted.Some are totally finished,some need decals etc.The paint is Zero Candy Lime Green and Zero Satin Black.The metallic flakes look quite large in the pictures but in reality are a lot smaller.The clear coat is Zero 2K again!!
I'll have more updates as I progress.
Steve Noble
Old 07-22-2007, 05:41 PM
Ole_L Ole_L is offline
Re: Kawasaki ZX12R Ninja
Good to see you on the 2-wheeler side... and nice start. This is another great Tamiya kit.
Old 07-23-2007, 12:25 AM
jmwallac's Avatar
jmwallac jmwallac is offline
Hot damn you work fast! You're really churning out some nice looking bikes! How about a Ducati next... Or maybe a race bike?
opcorn:
BTW, how do you attach the parts to the toothpick? I use puffy double sided tape, but its a real PITA.
Recently completed projects:
Old 07-23-2007, 03:56 AM
stevenoble's Avatar
I use Blue Tack to attach the parts onto the toothpicks.
http://en.wikipedia.org/wiki/Blu-tack
Steve Noble
Old 07-24-2007, 05:54 AM
janositamas's Avatar
janositamas janositamas is offline
It looks hot so far! I like this bike in lime green, I think it suits well. I may get one for myself...
Old 07-24-2007, 08:14 AM
Decs0105's Avatar
Decs0105 Decs0105 is offline
Registered User
here we go again
great start and once again the body parts painted with the zero colors look outstanding! At what air pressure do you spray them?
Old 07-24-2007, 04:57 PM
stevenoble's Avatar
Originally Posted by Thesaint111
here we go again
Although they are pre thinned,I usually add a little more thinner and spray them at around 20 psi.
Steve Noble
Old 07-24-2007, 08:28 PM
mrceej mrceej is offline
Looks outstanding!! I have one in the box that's been sitting for several years now. You make me want to build mine now.
Old 07-25-2007, 02:53 PM
joelwideqvist joelwideqvist is offline
Sweet! That green and black combo is looking great. Engine detail is really clean.
Joel
Old 07-25-2007, 04:34 PM
Decs0105's Avatar
Registered User
thanks for the fast answer but I got one more what about the clear, 20psi too?
Old 07-25-2007, 04:47 PM
stevenoble's Avatar
Yes,the clear is sprayed at 20 psi as well.Again I add just a little more thinner than is recommended,but not too much.My usual mix with the 2K clear is 5ml of clearcoat,2.5ml of hardener and 1.5ml of thinner (this makes half a cup on my airbrush.)The usual amount of thinner is 10%,so on the above ratio's it should be 0.75ml but I find the little extra thinner I add just makes it flow a bit smoother through my airbrush.It may not be necessary for certain airbrushes.To do all the green parts on the ZX12R I used a full cup (3 coats on each part) So if you double the quantities above there should be enough to do a full bike kit.
Steve Noble
Old 07-25-2007, 08:15 PM
jmwallac's Avatar
Less typing. More building!
I'm actually learning a lot here! Keep it up
Old 07-26-2007, 06:45 AM
stevenoble's Avatar
Another small update.I managed to shoe horn the engine into the frame.It was a pretty tight fit and was difficult to squeeze in but with a twist here and there it snapped into place.
Engine fitted to frame
I tried some Alclad chrome on the exhaust end can,but I really didn't like the look of it at all so I stripped it off and decided to go for a titanium finish instead of chrome.I am just adding some rivet details and may go for a touch of heat staining later on.The downpipe was left in the original Tamiya chrome plated finish.I checked some references and found that a Yoshimura RS3 exhaust can is available for the ZX12R in a titanium finish.The finish on the end can is Alclad Titanium.The Yoshimura logo is from a Dexter Models sheet.
The chain is also ready
More updates later.
Steve Noble
Old 07-26-2007, 08:51 AM
jmwallac's Avatar
Looks awesome! The Tamiya kit chrome is very convincing.
Old 07-26-2007, 10:36 AM
Twowheelsrule Twowheelsrule is offline
The exhaust can looks so real! I think you need to add your rivets to the outlet end just like the inlet and it will be a little better yet. If it wasn't for the screw in the picture it could be a real fooler.
Good job on the bike overall!
Mark
