Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 07-22-2007, 12:49 PM
lu4cor2 lu4cor2 is offline
96 neon running really rough
My neon is running really rough! It's a 96 2.0L sohc with 146,000 miles. have replaced spark plugs and wires. I have checked the resistance of the coil it is ok, Is it possible that the coil is bad even though it checks out ok! ALSO CHECK ENGINE LIGHT IS NOT ON! Can somebody please help. Anybody experience same issue? THANKS ANY HELP IS APPRECIATED!
Old 07-23-2007, 05:16 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: 96 neon running really rough
runs rough = idle rough? could it be a malfunction on the ignition timing? like the ECU isnt firing it correctly?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 07-23-2007, 10:46 AM
no its most likely not he ecu, I replaced that not to long ago. And yes the idle seems to be off, but not sure if it's jus the idle! I don't think its the timing, unless one of the other sensors help run that too?
Old 07-30-2007, 12:42 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Have you pulled the TB and IAC motor and given them a good cleaning?
2003 Dodge SRT-4
