2003 obd-II code 0102
This trouble code tells me there is a low input voltage to the maf sensor. Changed the maf yesterday to no avail car still runs rough after warming up
. It is the 3.0 DOHC engine. Any thoughts or suggestions on how to remedy this problem would be greatly appreciated. I'm pretty adept at fixing car engines except when it comes to all this electronic BS. I'm at a loss
Re: 2003 obd-II code 0102
Welcome to the forum!
According to the service manual, the following are items you should check:
Also, make sure that all the connections on the air intake are secure and you don't have a hose end rolled over or something. -Rod |
Well we dropped it off at the Ford Dealer today . Just got a call on it wich it seems to be that a temp sensor is telling the computer to shut the engine down because it is overheating(won't turn on the cooling fans either so the car will overheat). $138.00 to remedy this , so will see what happens. I'll keep you posted as to the outcome.Looks like a great Forum with alot of helpful peeps out there. Thanks Again, Rich
-Rod |
