Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-22-2007, 12:54 AM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
headlight wont work
So my aftermarket projector head light wont work, only the halo thing adn blinker...
my other head light works fine...
I replace the bulbs, check the fuses and everything is okay... IT STILL WONT WORK...
Any ideas, tommorow I figure I will disconnect the light assembly and try it out on a power inverter, if it doesnt work its a bad assembly if it does then the stock wiring has a flaw I guess which means I need to find it, or hook up my head light to a switch =[
HELP lol any ideas?!
T R U E E C L I P S E
1996 MITSU. SPYDER ECLIPSE
[email protected]
http://www.cardomain.com/ride/653950
Old 07-22-2007, 02:13 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: headlight wont work
Try hooking up your headlights in reverse and see if the problem moves with th light or stays on the same side. Obviously you won't be able to "install" them, but you should be able to hold them there while you plug them in.
95 Talon TSI AWD
97 Eclipse GST
Old 07-22-2007, 12:55 PM
What exactly do you mean reverse? I just dont understand this ...
[email protected]
Old 07-22-2007, 01:04 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Didn't you have to rewire the headlights because the plugs are different than the stock plug? I know I had to, thats why Garrett said to wire them up backwards. You may have crossed two of the wires in the process. I know I had to play with them to figure it out correctly...
Actually I think Shpyder posted a wiring diagram on here for them at one point in time...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 07-22-2007, 01:49 PM
By reverse I mean try plugging the right headlight into the left side and vice versa, and see if the problem follows with the headlight or stays on the same side. Sorry I should have specified better.
95 Talon TSI AWD
97 Eclipse GST
