Old 07-21-2007, 03:24 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
92 Bravada automatic no 3/4 gears
she drove it home in second at 5,000 rpm. no leaks, fluids full and clean. it was rebuilt about 35k ago. i'm going to take it to the tranny shop monday. any ideas or am i looking at another rebuild?
Old 07-21-2007, 04:40 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 92 Bravada automatic no 3/4 gears
You might check the TV cabel at the valve body.
Make sure it is not broke and has spring tensionon it.
MT
MT
Old 07-21-2007, 09:41 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
You had problems with the digital dash lights too right? Did you figure that out? Do you have a 4L60e or a 4L60? Late '92's got the electronic transmission. Maybe an electrical problem, but just specualting at this point.
Old 07-22-2007, 12:09 AM
ericn1300's Avatar
AF Premium User
MT
i checked the TV cable at the throttle end, its intact with spring tension and seems to be in adjustment, about a 1/8 inch defection until i feel spring tension.
yeah, the dash problems preceded the tranny problem by about two weeks but i didnt consider the problems related so i made seperate posts. not sure which transmission i have but but the vin is 1ghdt13w7n2704846 if that helps
Old 07-22-2007, 06:52 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
If it has the 4L60e, it'll have a 20 wire connection on the passenger side of the transmission.
Old 07-22-2007, 07:55 PM
ericn1300's Avatar
AF Premium User
its the 4L60. the TV cable is the give away, no solenoids. hoping its just a bad cable adjustment or bad throttle valve assembly but my experiences in the past tells me that the loss of the 3/4 clutches usualy means a complete rebuild. The rebuilder of my choice (not the shop that rebuilt it last) does have some after market electronic shift pack upgrades.
Old 07-22-2007, 09:05 PM
blazes9395's Avatar
Newbie mod
geez, thats too bad. Sounds like somthing wasn't done right or something gave out.
Old 07-25-2007, 02:52 PM
ericn1300's Avatar
AF Premium User
the planetary gears broke, metal everywhere. time for a complete rebuild. $1,500 bucks plus what ever the new gears cost. o well still less than four months payments on a new truck.
Old 07-25-2007, 03:22 PM
MT-2500's Avatar
AF - Advisor
Thanks for posting back how it went and what you found.
High repair but like you said only 4 payments on a new one.
Sometimes them gears can get expensive to.
You might price out a GM dealer rebuilt.
They are upping the warranty on them over the 50k to around 75K or more.
In the good old days I could get them for 1100 US dollars.
Good Luck MT
MT
Old 07-25-2007, 06:25 PM
ericn1300's Avatar
AF Premium User
Good Luck MT
Thanks for the reply MT. I called the dealer after reading your post to check it out and a GM rebuilt is $1,350 with a 3yr/100k warranty and that's for the tranny on a pallet only. The shop I'm using broke it out for me and the actual rebuild on mine is $940 plus $62 for the gears and includes a new torque converter and shift pack. The rest is R&R, fluid, flushing, EPA disposal fees, misc. shop fees, a fee for walking in the door, a fee for walking out the door, etc., etc., but after all is said and done I do get the job done with a 30k parts and labor warranty for about $400 less than going with the GM rebuilt with a parts only warranty. The GM option might make sence if I could do the R&R myself.
