Old 11-07-2002, 06:00 PM
TURBO_EK4's Avatar
TURBO_EK4 TURBO_EK4 is offline
Send a message via AIM to TURBO_EK4 Send a message via Yahoo to TURBO_EK4
Lightbulb Airbags
Hey guys, i need your help, would you guys happen to know how to make and install a mini-airbag suspension system for my models.
THANX!!
//Romeo\\
Newbies, Please Read This.
Old 11-07-2002, 07:21 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
It's never been done to my knowledge, but I assume it requires a lot of work. Making the miniature air bags would be the difficult part, and setting up very small hoses so it really works would be killer.
Old 11-08-2002, 03:21 AM
magicmanjk808 magicmanjk808 is offline
Send a message via AIM to magicmanjk808
i agree
i've thought about this before then i realized how impossible it would be so i decided not to try figuring it out anymore.
Current Project:
Fujimi Toyota Altezza RS200
bye bye handles, moldings, rain gutters, license plate holders
View some pics of it here http://www.automotiveforums.com/vbulletin/t72123.html
Old 11-08-2002, 05:09 AM
ales's Avatar
ales ales is offline
Forza Schumacher
I'm assuming your aim is ot have operational suspension? Well, if I ever decided to do that, I'd go with smallest electric moors on weach wheel with a fairly complex operation system (as well as a very complex system of limiting the movement of the suspension. This means siting behind the desk for a week trying to design the damn thing
Suspansion working on compressed air will be close to impossible in 1/24 scale.
Old 11-08-2002, 04:13 PM
TURBO_EK4's Avatar
ITS AN AUTO TECH PROJECT AND IT HAS TO BE W/COMPRESSED AIR.
BUT I AM ALSO THINKING OF GOING W/A BIGGER MODEL NOT 1:24 SCALE.
//Romeo\\
Old 11-08-2002, 04:28 PM
ales's Avatar
Forza Schumacher
OK, OK, no need to shout!
Old 11-08-2002, 04:45 PM
TURBO_EK4's Avatar
WAS I SHOUTING?:huh:
//Romeo\\
Old 11-08-2002, 05:08 PM
BWheel BWheel is offline
Have you looked at Lego building blocks? They have a very good suspension system.
The other option you could look at, which I've seen working quite effectively on a larger scale is to use small piping connecting to syringes. By having a large syringe as your 'reservoir', leading to 4 small syringes, you'd have a pretty good system, where you could pump the system up and down.
You'd want to fiddle a lot with this. Air would work OK-ish, but also water. You could even have quite a long tube as a lead-up to the model.
Don't know about remote controlling a system like this. You'd need some real funky systems to use an actual pneumatic system.
Remember, you can go right down to diabetic syringes that are really small. Your pressure area is real small though, so could be an issue. Probably 5ml as your pistons, and a big ole 200ml for the 'reservoir' would probably work the best. Fluid also works better than air, due to compression etc.
Good luck with it, and have fun....
Old 11-08-2002, 05:13 PM
THe concept from a hoppin hydros kit might come into play, although I have never seen or used a hoppin hydros kit in real life. Just a while ago while driving I saw a truck that had airbag suspension on it, but some punk switched lanes and got in front of me so I couldn't see the actual makeup of the system. If you wanted it to be very realistic, you'd need to setup a central "hub" type object that has a central gate for the air, and then 4 individual gates for each corner of the vehicle. Then have the appropritae tubing running to each wheel, and then find yourself a shop that does custom rubber and metal work, then ahve them make the mini air bags. After that you'd need some sort of a relay system between the central hub and a remote control. I honestly would love to see or design such a thing, but the time and money required is above what I feel is reasonable.
Old 11-08-2002, 05:23 PM
Here's a little concept drawing.
Old 11-09-2002, 06:37 PM
TURBO_EK4's Avatar
i just bought a 1:18 scale model Escalade!! I think that this size should make it easier.
Thanx guys 4 ur input!:flash:
//Romeo\\
Old 11-10-2002, 03:44 AM
Purpura Delujo Purpura Delujo is offline
What is it with people adding rims over 20" to excalades and making them scrape the ground etc etc? I think they look like shit!
Old 11-10-2002, 04:28 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Lego used to have smallish air operated pistons.
They were about 3inchs long, and had a range of motion of about 1inch
I dont know if they still make them, but they would be perfect for a larger scale model suspension.
