Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 07-21-2007, 01:40 PM
Donnie39 Donnie39 is offline
ABS Disconnect
I have a 96 Continental, the abs system makes a loud noise ( actuator motor?)and the pedal pulsates at low speed when turning. I have been running it for quite some time with the abs disconnected and the brakes work fine. Question, is there a way to bypass the abs system so the abs warning light & the check traction system warning will not come on (maybe a jumper wire?)
Thanks
Old 07-21-2007, 06:07 PM
Towncar's Avatar
Towncar Towncar is offline
Re: ABS Disconnect
Originally Posted by Donnie39
..Question, is there a way to bypass the abs system so the abs warning light & the check traction system warning will not come on (maybe a jumper wire?)
Dereck at LoL might know a workaround.
Seems to me it'd be relatively inexpensive to fix the problem, most are traced down to a wheel sensor.
-Steven
1996 Town Car, Cartier
