serpentine belt
my 2000 montana continues to eat/throw belts. i've replaced both idler pulleys, and the tensioner. help.
Re: serpentine belt
I recall another thread that mentioned that the harmonic balancer on the crankshaft can deteriorate, and the pulleys no longer align...I'd examine the crank pulley/balancer for damage and/or rubber becoming visible.....Glen
Re: serpentine belt
glen,
thanks for your reply. the general consensus seems to point to the harmonic balancer. wish it were as easy to r&r as the one on my '64 chevy p/u. thanks. |
Re: serpentine belt
Yep, understand....I seem to recall that if you jack up the FR wheel and remove the small splash shield, you can get to the bolt relatively easily.....good luck! Glen
Re: serpentine belt
don't know if it's wishful thinking, or if it's actually the culprit. do you remember if a impact wrench is required? how about a puller?
I don't know if you have to lower the engine in order for the harmonic to clear the frame or not. If I was doing this myself, I would probably figure it out based on easiest approach. The impact would be nice, but a straight bar (also know around here as a Johnson bar) and an extension will remove the bolt in the front of the harmonic. The puller is a must. Replacing the new harmonic should be a lot easier. Remember to replace the front seal and grease the harmonic where it touches the seal to make sure the thing doesn't run 'dry' at start-up. |
Re: serpentine belt
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Re: serpentine belt
o.k., thanks for all the good advice. i've replaced the harmonic balancer, and the belt now rides true on the idler directly above it. however, at idle i noticed a stumble/hesitation every so often. as far as driveability, the shift points are different, and it does not pull cleanly through the gears. the hesitation at idle seems to be gone though. is the sensor adjacent to the balancer counting rpm for the at? any thoughts?
PS - Can you share with us how you removed the harmonic so we all know how you did it? |
