Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-21-2007, 11:44 AM
kevinfrederickson kevinfrederickson is offline
95 ranger unusual squeak coming from engine
I had descovered a squeak in my engine thinking it was the belt i changed it and now the squeak is even worse. just wondering if anyone had an idea what the damn squeak would be?
Old 07-21-2007, 08:57 PM
nymorey nymorey is offline
Send a message via AIM to nymorey
Re: 95 ranger unusual squeak coming from engine
Last time I had a squeek it was the alternator bearing.
Use a long screw driver or stethoscope to see if you can narrow where it is coming from.
Old 07-21-2007, 11:06 PM
DonSor DonSor is offline
Run your engine but turn your A/C (if equipped) off. Does the squeak change any if you rev up your engine? Do you have a serpentine belt? Although you have a new belt try suirting water from a sprayer over the pulleys and note if there is any change. A noise from a bad alternator bearing is usually more of a howling noise and it is steady. I suspect that it is your water pump that is going out. If it, the next symptom will be that it will start to leak from the pump drain. Once that happens you better get it replaced because it could overheat and freeze.
Old 07-24-2007, 04:42 PM
yea i thought it might be the bearing also but i sprayed some belt conditior on it and all over all the pulleys and belt and it didnt really help so i dont know if it is the bearing or not. also i still cant seam to narrow where it coming from it sounds like its coming from the pulleys but sometimes it also sounds like its in the back of the engine.
Old 07-24-2007, 07:36 PM
Try squirting a little WD 40 on each bearing, one at a time and see if it stops. That's how I found mine. On my alternator I also squirted the shaft bearings.
Old 07-24-2007, 08:45 PM
i tryed that and it didnt help but i have narrowed that the squeak is coming from the back of the engine. Any idea what it would be?
Old 07-24-2007, 11:24 PM
It's difficult squirting water or lube on a bearing because they're mostly sealed. Are you sure the squeaking noise is not coming from the water pump?
Old 07-25-2007, 10:18 PM
wmcclay wmcclay is offline
Try taking belt off and spinning pulleys by hand, do not forget the tensioner
