Old 07-21-2007, 03:04 AM
GNRAxlRose88 GNRAxlRose88 is offline
Send a message via AIM to GNRAxlRose88 Send a message via Yahoo to GNRAxlRose88
'93 Blazer...check engine light on
Now, before you call me an idiot read the whole thing.
I just got a '93 S-10 Blazer from the estate of a deceased friend. I know minor problems that need to be worked on but one i just found out today.\
When i stop for a short period of time (usually about 30 seconds of idleing) the "service engine soon" light comes on. When i begin to drive again, the light goes off.
I know about 3-4 years ago he replaced the motor with a remanufactured one. It's the Vortec 4.3 fuel injection.
I don't know much about s-10 Blazers, i'm more of a Bronco guy. I just picked this up as a beater to use while i work on my two Broncos. I don't want this to cause a a huge problem, so i'm addressing it now.
Any help? Thanks!
Old 07-22-2007, 03:08 PM
Cam1959 Cam1959 is offline
Smile Re: '93 Blazer...check engine light on
Something that drops when low rpm and rises with higher rpm, like oil pressure, vacuum ?
1983 S10 4WD carbed 2.8L automatic w A/C
Old 07-26-2007, 10:03 AM
brandon200317 brandon200317 is offline
could be a number of different things, go someplace and get the code read, if the light isn't on when read, it should still be in the failure history records. i believe places like tires plus do code reading for free, but don't let them replace or fix anything, the'll just shotgun a part in and call it good enough haha
Black 01 silverado LT z71. 5.3L extended cab.
Black 2000 Mercury Mystique LS, 2.5 v6 5 speed.
