Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-07-2002, 01:40 PM
baldy74 baldy74 is offline
overheating issue...
I have a 1991 Prelude 2.1L Si. For some reason, when the temperature gauge starts to get too high (it actually max's out) the radiator fan never turns on to cool it off. It usually gets hot when sitting in traffic, and the minute I start moving the needle goes back down (from forced airflow). However, if I turn on the A/C then both the A/C fan and the radiator fans come on. They will stay on for a while, then turn off, then turn back on. Pretty normal there. As soon as I turn off the A/C both the fans will turn off and the radiator fan won't come on unless I use the A/C again. Finally, when I turn off the car, the radiator fan will come on.
Could anyone please help me here? This is actually my winter beater, so I am trying not to have to spend a lot of money on her (ie a mechanic). TIA, guys.
Old 11-13-2002, 04:13 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
inspect the fan relay. if it check out fine, then replace the radiator fan temp sensor.
Old 11-17-2002, 07:50 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
Hi drift! Nice to "see" you again! What happened to PH??
Old 11-17-2002, 08:39 PM
drift's Avatar
shut it down. i didnt have enough time to dedicate to it
Old 11-20-2002, 07:51 AM
slikk's Avatar
slikk slikk is offline
Send a message via AIM to slikk Send a message via Yahoo to slikk
over heat
yooo u we got the same kind of ride .. ~s~w~e~e~t~
sound like your wiring if f*&ed ^ have an electrican check it out .. or that relay shizzle that drift was talking about
good luck
--drive it like you stole it--
