Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-20-2007, 03:18 PM
Bondojoe Bondojoe is offline
91 Regal 3.8 Won't Start
3.8 L with 182,000. It was running fine and my wife started it and it died. You can crank it and it will just turn over. It sound like it wants to start but will not. It doesn't give any codes and it has fire and gas. I'm thinking ecm or it has jumped time.
I'm going to do a compression test tonight to see if it might have jumped time but wanted to know if it would have low compression if the ecm is bad?
Any advice would be appreciated. Thanks
Old 07-20-2007, 03:54 PM
motocip motocip is offline
Re: 91 Regal 3.8 Won't Start
Mine did the same thing and the fuel pump pressure was low. Ended up replacing pump and problem fixed. Just an idea.
97 Buick Lesabre Limited 221K
98 Cadillac Deville standard 144k
96 Cadillac Eldorado ETC
96 Lincoln Mark VIII
66 Pontiac GP 421 Tri power
Old 07-20-2007, 04:05 PM
maxwedge maxwedge is offline
A990 racer
Welcome to AF. Has gas? How much fuel pressure, you need 40 psi at the rail.
Old 07-30-2007, 08:59 PM
The car has 42 psi at the rail. I'm thinking if the car jumped time that the compression would be low. I'm going to check it in the next couple of days and if it is ok I'm thinking maybe the ecm. Am I on track and does anyone have any other suggestions? Thank You in advance. Bondojoe
Old 08-07-2007, 10:59 AM
Bump
Old 08-07-2007, 03:11 PM
Mickey#1 Mickey#1 is offline
You already checked fuel pressure so now you need to check for spark at each of the three front cylinders & fuel injector pulse.
Old 08-18-2007, 11:29 PM
Problem solved. I went to check and see if the timing chain jumped and when I pulled off the harmonic balancer it was broke in 3 peices where the key goes.
