Old 07-20-2007, 01:03 PM
javatrooper's Avatar
javatrooper javatrooper is offline
'99 idle problem driving me crazy
I have a 1999 SE Escort, single overhead cam. The idle will constantly goes up and down. Goes up for about 2 seconds, then back down for about 3 seconds. This cycles over and over. I've replaced the idle air valve twice, can't find any vacuum leaks, unplugged the AC compressor, replaced the MAF sensor........I'm completely stumped. Please help.
Old 07-20-2007, 01:16 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: '99 idle problem driving me crazy
Just because you can't find a vacuum leak doesn't mean that there isn't one...
If you haven't done so, when the engine is running disconnect one of the hoses from the vacuum port on the intake and plug the hole. Look for changes in behavior. If none, plug it back in and disconnect another... see if you can get the engine to stop surging and you might be able to identify which direction to follow the vacuum lines.
If this doesn't lead anywhere, check into your fuel supply... plugged filter, pressure regulator, etc.
Old 07-21-2007, 08:59 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
you also could spray some carb cleaner around vacc lines and if you hear a change in idle that line may need looking into. You mention that you replaced the iac two times did you notice if the gasket was in good shape and not leaking there? did you look inside the intake and see how much carbon/gum may have build up inside there and the throttle body?
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 07-21-2007, 09:51 PM
Thanks for the suggestions. This is one of 4 cars I'm working on right now, but as soon as I get a chance to I'll check it out I'll post the results. Mahalo...
