Old 07-20-2007, 12:55 PM
ajs2205 ajs2205 is offline
clio radio
need help to fit a radio in clio ( R REG ), can anyone tell me what wires go were as the previous owners have cut the blocks of and removed the radio.
thanks tony
Old 07-20-2007, 03:34 PM
AWP9521 AWP9521 is offline
Re: clio radio
With the advent of harness adapters, hearing that somebody still has to cut the factory connections off to hook up an aftermarket unit almost makes you want to slap them silly.
Best thing I can advise is to see if you can get a copy of a wiring diagram for the radio leads from a dealer so you can hook up your new deck.
Or go to a wrecking yard and find a vehicle like yours and get the harness ends with enough wire coming out of them and splice it into your harness matching color for color of the wires.
If either is not possible then your only option is figuring out which wire is which, using a multimeter set on ohms or continuity you can easily find the body ground (NOTE: Disconnect the battery before using an ohm meter or you will blow the meter or it's fuse if you test a live wire! One wire of the meter to the body and the other on a wire with the meter reading 0 ohms or a beep if using the continuity checker, any reading above 0 ohms is a power or speaker lead), then with the multimeter set at DC volts with the black lead to the car body you can find the ignition switched (with the key on of course) and battery power leads as well as the the instrument lighting (With the headlights on) leads, it's the speaker wiring that will be the pain, with one lead of the multimeter long enough to reach the back of the car and the meter set to ohms or continuity though you can chase each speaker wire down, hopefully the speakers are at least marked + and - then you can label all the wires at the dash end as you figure out what wire is what.
Either way, if you do any of that, it is ideal to solder and shrink tube all connections, don't use those crimp connectors to join the wiring, they are too unreliable and usually pull apart easily.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 07-20-2007, 06:00 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: clio radio
what is a clio ?
Old 07-21-2007, 02:09 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: clio radio
Car made by renault in europe
http://www.renault.co.uk/Productpage...spx?mm=newclio
Kind of reminds me of the new toyota yaris a little bit.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 07-21-2007, 10:24 PM
Audio Guy
Re: clio radio
Renault cars are not very popular here, so the info will be kind of limited. Have you tried the Renault forum on here ?
