Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-20-2007, 12:01 AM
Luke26 Luke26 is offline
Need Help to change the Starter
I have a 98 gs-t and the starter has gone bad. I took the car to a mechanic and he said that it was just the wire to the starter and he replaced it. the car worked fine for about a half a day and now it won't start again. I still have a new starter in the box and just need some helpful instructions on how to go about changing it out. Any help would be great. thanks
Old 07-20-2007, 01:12 AM
steviek's Avatar
steviek steviek is offline
Re: Need Help to change the Starter
before you replace the starter why don't you make the mechanic fix his work that he didn't do properly?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 07-20-2007, 06:36 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Its easiest from the underside of the car... Reach up there and unhook your wires from the starter. Take the two bolts out and slide it straight out. Slide the new one straight in. If it doesn't go in right, pull it out and turn the gear slightly and try it again. Then put your two bolts back in and reconnect your wires...
Are you sure its the starter and just not a starter relay gone bad? Or even a loose wire on the starter. Bad connections can cause the most severe problems sometimes...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 07-20-2007, 10:14 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
If you remove the battery, taking out the starter is a snap. It's tricky the first time you do it (And can take a bit of time) But once you do it once it's super easy. I've always done it from the top.
1991 GSX 2.3 Stroker
Old 07-21-2007, 12:41 PM
eclipsemaster94 eclipsemaster94 is offline
The last post is pretty much on the dot. The cars starter is on the back side of the motor. Disconnect the Battery, take out the battery, with tray, and you can disconnect your intake hose from the throttle body, and move it out of the way to give you a little more room....you can see the starter, with two bolts in it. Remove the two bolts and jimmy it out, after you do it a few times, it comes pretty easy. I find it easier taking the starter out from the top...Tj
Old 07-21-2007, 12:44 PM
thanks for your help.. i'm gonna give it a shot tomorrow..
thanks again
