Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 07-19-2007, 09:03 PM
DWA DWA is offline
Unhappy 2001 Dokota Overheating
I have a 2001 dokota with a 4.7 v8. My engine will come to temp and stay for a while then it will slowly creep up. If I turn on the heat in the cab the temp goes back down. I have replaced the stat, and the fan clutch still know change. Can any budy tell me whats wrong
Old 07-24-2007, 12:45 AM
vamc's Avatar
vamc vamc is offline
Re: Overheating
Wrong mixture of antifreez maybe?
Old 07-25-2007, 07:07 PM
Andydg Andydg is offline
Re: Overheating
Did you get all the air out of the cooling system when you replaced the thermostat? If you don't get all the air out, the water pump has trouble keeping the fluid moving.
Old 07-26-2007, 01:24 AM
vamc's Avatar
Re: Overheating
Bad temp sencer?
Old 08-11-2007, 08:42 PM
rhandwor rhandwor is offline
Re: Overheating
Check the bottom and top radiator hose when running. Are both hoses hot a partially plugged radiator will cause your type of problems. Look in the cap and check for good circulation.
Old 12-28-2007, 01:22 PM
ryobiguy ryobiguy is offline
Cool Re: Overheating
I had the same problem with a 99 3.9L the radiator was the problem. I found this out after changeing the water pump, 3 thermastats, belts, hoses, checked timing, removing the exhaust for back pressure. This could have been avoided by checking the tempeture with a ir temp gun at different places on radiator. The lower temps means the radiator is plugged. This caused by the pink or extended anti freeze. Antifreeze needs to be changed yearly. Good luck:Ryobiguy
Old 01-04-2008, 01:08 PM
master hec0's Avatar
master hec0 master hec0 is offline
Send a message via MSN to master hec0
Re: Overheating
i had a similar problome on my 2000 dodge dakota 1st time it was a rad leak 2nd time it was just low rad fluid
also if it is a air bubble in the system open rad cap and leave it running and it should get out of system
Crop circles are Chuck Norris way of telling the world that sometimes corn needs to lie the fuck down
The Great Wall of China was originally created to keep Chuck Norris out It failed miserably
A Handicapped parking sign does not signify that this spot is for handicapped people. It is actually in fact a warning that the spot belongs to Chuck Norris and that you will be handicapped if you park there
When the Boogeyman goes to sleep every night he checks his closet for Chuck Norris
