Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 07-19-2007, 08:59 PM
joshnotjoshy joshnotjoshy is offline
1994 Headlight Issues
Hey everyone, I'm having some troubles with my Intrepid. Both of the headlights went out at once, thus I checked the most obvious stuff first. I changed and replaced fuses, I checked and replaced a relay fuse under the hood, I even bought new headlights for the car. Nothing.
I am desperate. Do any of you fine folks out there have any clue what else I can do to fix this problem without having to spend some major bucks at a shop? Much appreciated!
Old 11-04-2007, 03:25 PM
mojustice mojustice is offline
Re: 1994 Headlight Issues
did you test the head light switch?
Old 11-04-2007, 09:26 PM
rhandwor rhandwor is offline
Start at the connection to the bulb use a 12v test light you should have power. If you have power check for a corroded ground connection. Corriosion is the cause of many problems with lights.
