Go Back   Automotive Forums Car Chat > Cadillac > DTS
Old 07-19-2007, 05:58 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
02 Cadillac DTS will not start
A friend dropped his 02 DTS off at my house, I am currently rebuilding an engine for him for his truck. Well he told me he got gas and was pulling out of the station and it shut off on him and would not restart.
Well I took a quick look at it yesterday when I got home from work. The FUEL PUMP is not kicking on, I checked fuel pressure and have 0 fuel pressure. Checked the fuel pump relay and fuse under the rear seat - swapped the relay with another one and the fuse was not blown and still nothing. Before I tell him it's the fuel pump I was wondering if anyone knew of any other causes for this, anything else that would keep the Fuel Pump from kicking on.
Thank You
Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 07-19-2007, 06:04 PM
caddydaddy caddydaddy is offline
Re: 02 Cadillac DTS will not start
The only thing else I can think of would be the security system. It wouldn't hurt to check the computer codes for any security system problems. But a security system problem should illuminate a light on the dash and display a message.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 07-20-2007, 07:07 AM
I checked the security system, the security light flshes when you opent he door but aas soon as you turn the key to the ON psoition the light goes out, so i don't think it is a security problem. Any other thought, I would just hate to replace the pump and that not even be the problem.
Old 07-20-2007, 01:09 PM
That's why I said to check the computer codes to see if something else is preventing the car from starting.
2000 Cadillac STS
Old 07-20-2007, 08:36 PM
is there anyway to check the codes without a OBD-II Scan tool, does it have a self diagnosis like on my jeep?
Old 07-25-2007, 05:36 PM
UPDATE:
I just replaced the FUEL PUMP - very easy JOB (30 minutes IN and OUT), for all of you that don't know this - there is an access plate in the trunk, passenger side toward the back of the rear seats, 5 bolts holding the plate on, remove the plate and you will be able to get to the fuel pump.
The car starts and run good now.
Joe
Old 07-25-2007, 09:48 PM
Good, glad to hear you got it fixed! For some reason those Cadillac fuel pumps don't last too long. Mine died at around 4 years old and 60k miles.
2000 Cadillac STS
