Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-18-2007, 09:19 PM
inatalonIXLR8 inatalonIXLR8 is offline
Question Expertise greatly needed - 2.4 stroker
Hopefuly someone here has already worked through all the finer aspects of piecing together a frankenstien project like mine.
I'm putting a 4G64 2.4 L stroker in a 95 AWD Talon using a built up block from a 91 Sonata, and a 1st Gen head.
Question #1 Will a 90-91 turbo Talon oil pan work for this aplication?
Question #2 Is the black top 93-94 Cam Angle Sensor the one to use? (that's the magnetic one not the optical right?)
Question #3 I also need the water pipe and thermostat housing. Will all the years between 90-94 be the same?
Question #4 Are any of these parts the same on a non turbo model and are there any differences between the Eclipse, Talon, and Laser even in build quality?
These are the last items that I need to finally get my baby going again, thanks for any input.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 07-19-2007, 01:01 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Expertise greatly needed - 2.4 stroker
1, yes, only turbopan with oil retun hole
2, Blacktops are optical and just have better resilution, any 1g cas will work, Non & Turbo models
3, 90-92 turbo T-stat, non turbo dosen't have the extra coolant nipple. 91-92 turbo waterpipe if you're using a water/oil cooled turbo, 90 turbo waterpipe if only oil cooled turbo.
I know there are a couple dedicated forums and websites to this swap, even a very long thread on tuners...
DSM geek
Old 07-19-2007, 01:37 AM
Right on......Thanks so much for the detailed information. I don't surf the net too often, are you refering to DSMtuners.com, or is there a thread on Automotiveforums that I should refer to?
Old 07-19-2007, 08:41 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
When you say 2.4 stroker, is it going to be an actual 2.4L, or a regular 2.3L like most other stroker guys run.
Here's a nice little write-up about an actual 2.4L
95 Talon TSI AWD
97 Eclipse GST
Old 07-19-2007, 10:29 PM
G4CP engines are true 2.4l.
DSM geek
Old 07-19-2007, 10:33 PM
Yes it is an actual 2.4L
I am not really that familiar with looking up threads, I have tried searching in automotive forums but haven't yet found the write ups on the 2.4L
Is there something in particular you would recommend reading ?
What kind of vehicle does a G4CP engine come out of ?
Old 07-19-2007, 10:37 PM
Oh shit, sorry about that, I forgot to post the link....my bad.
http://www.pinktemple.com/stroker.html
95 Talon TSI AWD
97 Eclipse GST
Old 07-20-2007, 12:33 PM
Thanks for the article. I'm using the Sonata block, so I shouldn't have some of those clearance issues. But I probably will have to hammer out the oil pan. You saved me from having to find out the hard way!
THANK YOU.
Old 07-23-2007, 09:12 PM
Just need to clear something up if anyone can help. Is the black top Cam Angle Sensor off of any 93 - 94 Talon, Eclipse or Laser except the 1.8L Laser ? -thanks
