Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-18-2007, 11:39 AM
kenc195 kenc195 is offline
Brake Switch Interlock
2000 Towncar wouldn't come out of park this morning and the brake lights are out. Where is the interlock, whats a fair price on it and how hard is it to change. I was able to put it in "N" to start it and drive it but with the lights out, not good
Life is good with my 97 Passport
Old 07-18-2007, 04:28 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Brake Switch Interlock
There's a solenoid on the steering column that actually does the locking job however, the problem is most likely the (BOO) Brake On Off, aka Brake Light Switch.
Some folks report "the switch seems to be knocked out of place, I fixed it with two fingers" and others report "one wire was unplugged, it works fine now" while others report "the switch was replaced and all is well". ( the latter was probably done by a mechanic and cost a first born )
The switch is located inline with the brake pedal arm.
-Steven
1996 Town Car, Cartier
Old 07-20-2007, 02:17 PM
Sure enough, I see a loose wire but it is behind a plastic molded shield. Any idea how that comes out. I'm a pretty large guy and exploring under there is not pretty.
Old 07-20-2007, 06:13 PM
Towncar's Avatar
Sorry, I can't say for sure on your 2000 model.... you may want to find someone smaller to play with it..
I usually get my wife involved where I don't fit....
-Steven
Old 12-15-2007, 02:33 PM
tcjimmy tcjimmy is offline
Is there any adjustment to the brake light switch. My 93 TC I have to push the brake as hard as I can before the Brake Lights come on. Also the park interlock does not work I have to start it nuetral.
Old 12-16-2007, 08:10 PM
Towncar's Avatar
It not adjustable, but it may have fallen loose from it's mount, or just plain defective. You'll have to get under there and have a good look.
-Steven
Old 12-17-2007, 09:21 AM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
There are a few different switches under there, on the brake pedal bracket. Most likely you need to replace one. I have some if you need any.
Can you start the car with the shift indicator between P and R ? It might be out of adjustment, easy fix. Or there might be something wrong with the neutral safety switch. I have some of those as well. [email protected]
Mike
