Dashboard fan gone
1st post.... great site!
I have a 2002 Taurus that I have been fighting with for the better part of a year and almost $4500 later.. still not perfect... grrrr... Go to a mechanic they guess.. go to the dealer they cost good money! ![]() Well -- it seems that after a year or so of a noise from the a/c fan in the dashboard, it has gone the way of the dodo bird. I only get feet or windshield (or both) but nothing through the dashboard vents. As I have yet to do really do any work on this car (but all previous cars I did) I figured I need to try and combat this myself. Is the fan easily accessed through the glove compartment or some other point? Would anyone know what part number the fan is? Thank you, Tom |
Re: Dashboard fan gone
On my '02, is the same fan motor that powers the air thru all the vents. Have you considered that you may have a diverter door problem?
Remove the glovebox and will find the motor behind. |
Welcome to the forum!
As Willyum suggested, the blower motor will not be your problem. It sounds like you have either a vacuum issue (if manual HVAC controls) or a servo issue (if you have the electronic HVAC controls). You may want to review the appropriate control diagram for your system to determine the likely source of the issue. We can help you out there too if you let us know which system you have. -Rod |
So you have the electronic temperature set point for the desired cabin temperature? That being the case, there is a diagnostic procedure for the HVAC system that may hint to you what the issue is with your car.
The diagnostic procedure has been posted before, try using the "Search this Forum" feature from the Taurus forum main page. You may want to search for the keyword "EATC." -Rod |
Thanks again! Last edited by TDonoTaurus; 07-19-2007 at 05:35 PM. |
-Rod |
-Rod |
and BTW -- Thank you again.... |
Well, I'm going to get into semantics a bit here. "Cooling system" in this industry is the system involving the engine coolant (aka antifreeze). Heat/Ventilation/Air Conditioning (HVAC) is just how it sounds. The codes 051 and 053 are related tot he HVAC system rather than the cooling system. The tie between the HVAC and cooling systems is that the coolant flows through the heater core for the "heat" portion of the HVAC, but that is not relevant to the codes you are reporting.
Ding, ding, ding! I think we have a winner! I just checked the service manual, the Autolamps (headlamps) use the same photocell as the Electronic Automatic Temperature Control (EATC). The sensor is located in the dash panel above the glovebox. To remove the sensor and test for the open condition: Photocell and Amplifier Removal
Well -- strangely enough now all the blowers don't work (and the headlights still stay on in the Auto mode) ... I have made an appointment with a mechanic here and was armed with the info you gave me. He ordered the sensor and will install it.. hopefully it will erradicate the situation. If it doesn't... and the fuses also don't correct it.. do you have any further suggestions? The code are still the same.. 051 and 053 so at least that is still consistant. I wish I could get around in a horse and buggy....
Does the blower motor by chance work in the high speed mode, just not the slower speeds? If so, coincidently the blower motor speed control (PWM motor controller) may have failed now too. When the blower motor controller fails, usually the high speed relay still works.
-Rod |
I hear the flaps opening if I turn on the a/c... just no fan at all... and the headlights still on. runaround ![]()
