Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-18-2007, 10:05 AM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
No dash lights?
Well I figured it was a fuse when I turned on my lights last night and no dash lights or anything inside went on. The headlights and foglights were on but no dash lights. I checked for the fuse but didn't find one, does anyone know that it is a fuse for sure and if so which one?
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 07-18-2007, 11:47 AM
nova1313's Avatar
nova1313 nova1313 is offline
Re: No dash lights?
fuse is in engine bay. It's actually always for me been the one with the fuse puller attached to it. I just pull it up when I'm working inside and push it down after. It takes 2 spaces. It controls all inside lights and trunk lights. I think it may be listed as the fuse for the radio...
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 07-18-2007, 11:54 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: No dash lights?
if the fuse is still good, check the dimmer!!! took me forever to fix mine because all the fuses where good, and the damn dimmer was bad...
Old 07-18-2007, 12:38 PM
Re: No dash lights?
the dimmer fuse?
SOLD
'97 GSX
Old 07-18-2007, 04:03 PM
Black99GST's Avatar
Re: No dash lights?
mine was the whole dimmer switch, i replaced the whole thing, been working great ever since... i guess the internals in it are really weak... i had a floating voltage, meaning the power wire to it had power, the ground was grounded, but the lights didnt work. if you have exhausted the fuses, and any other of your ideas, replace the dimmer switch, its about $80 from Mitsubishi, or you can find someone will a parts car that will work. no worries if its a different coler, because you can just pop out the dimmer from the case, and put it back in your case... hope that helps.
Old 07-19-2007, 11:38 AM
Re: No dash lights?
I checked that radio double fuse and both of those 10 amps were good. Then I started pulling others for the hell of it and it ended up being the tail lamp fuse? It was blown so i replaced it and now the dash lights work. It's a 15 amp fuse but what does tail lamp have to do with that?
SOLD
'97 GSX
Old 07-19-2007, 10:33 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: No dash lights?
Hmm..seems like someone messed with some wires they shouldn't have.
Not saying you exactly but someone at some point possibly.
2004 Mazda 6i
1997 Tahoe
