Old 07-18-2007, 08:44 AM
Warp50 Warp50 is offline
Interference motor or not?
Just purchased a '98 2.4L with 102,000 on it for my daughter. I would like to know if this is an interference motor a non-interference. Is there a recommendation on when the timing belt/chain should be changed?
Thanks for your answers....
Old 07-18-2007, 09:10 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Interference motor or not?
Non, When the water pump goes bad most people change them then as they have the remove the timing change to do so. Water pumps go bad 80-100K miles or so. If yours still looks like stock, kill a weekend and do both of em for her car.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 07-21-2007, 09:01 PM
wannablast wannablast is offline
It has a timing chain. Mine is a '97 with 207k miles on it. It runs fine. I've had to replace the fuel pump inside the fuel tank recently and the catalytic converter a year or so ago. The exhaust pipe broke up where it bolts to the head. It had an accordian looking expansion section and corroded and busted off. The fuel pump problem was a long cranking time when the car had sat for a bit. It started well if it had recently been ran. It is my understanding that there is a check valve that goes bad and allows the pressure to bleed off when it is sitting. I use 10w30 synthetic oil and don't change it until I get 10k miles out of it. I just keep it topped off and I check it at fuel stops. 29mpg in the winter and 31-33mpg in the summer. It does not tick and runs smooth. I've heard a bunch of them that did tick with much fewer miles though.
Good luck and show your daughter where the dipstick is.
Old 07-21-2007, 10:04 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Errr...you crank those cams backwards and you will bend valves...
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 07-24-2007, 01:39 AM
Shen Bond Shen Bond is offline
Red face Re: Interference motor or not?
If you say, Interference motor or not?.....
I will say Yes.......because If yours still looks like stock, kill a weekend and do both of em for her car.
Sahne Bond
http://clearblogs.com/thecandles/
