Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 07-18-2007, 02:32 AM
toolfan8102 toolfan8102 is offline
Which handheld tuner is best?
Which handheld tunerdo you guys reccomend? Are they worth the money?
92 STS
Old 08-07-2007, 12:16 AM
bc4 boy bc4 boy is offline
Re: Which handheld tuner is best?
well most the ones off the shelf are not worth the money but if i had to say i would say hypertech. but if you would like to do it the right way get stackables. get the stage 1 jet chip then the stage 2 jet chip. after u get those the the venom 400 accel chip summitracing offers that would dominate i would no because i did it to my car. about 800 bucks and a day of work. but if u are serious about your car this would be the best way to go. gain about 80 horsepower.
Old 08-07-2007, 12:53 AM
thanks
have you had any reliability problems with it?
is the 80 hp including all your mods or just that chip?
92 STS
Old 08-07-2007, 03:16 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Be sure to check SCT.
Old 08-09-2007, 12:03 AM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
Are you out of your fucking mind? Please don't post again, but like the other guy said check out SCT.
Old 08-12-2007, 10:16 AM
eillob's Avatar
eillob eillob is offline
Thats about he worst advice I ever read. Buy three seperate chips spend $800 on the last one and get 80hp?
First off I believe the thread was asking about handheld tuners if Im not mistaken. Stay away from hypertech and Jet chips there off the shelf junk. All they do is advance timming and improve shift points in auto trannys. SCT is better but your still stuck having to get it reburnt everytime you make a change to the car. No chip or tunner will net you 80hp. AFR heads won't get you 80hp.
Personnally I like the PMS. Thats what I use so thats all I will speak on. After doing a little research I found it to be one of the best tunning devices on the market. Its expensive but it is the last tunning device you will ever need. Very user friendly and allows you to monitor how your car is running at all times. This isn't the answer for everyone however. Me Im always making changes to my car, so for the long haul this is a good answer for me. You need to ask yourself what your future plans are for the car first before you start spending money on tunning.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
