Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-17-2007, 10:52 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Shot in the dark.........
Since there is nobody in the tempo forums I will try here. My 2.3L when it gets hot will die like it is not getting any fuel and then not start until it cools off. Now I know they are front and rear wheel drive versions but there has to be some similarities. Now the fuel pump is new and so is the filter, and i replaced the cap, rotor, wires, and plugs and still no luck. Any advice would be great.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 07-18-2007, 01:56 PM
wintonboy wintonboy is offline
Re: Shot in the dark.........
Sounds like a similiar problem I was able to cure by changing the engine coolant temperature sender. You can check by probin the resistance through the sensor at different temperatures. Haynes manuals have the proceedure.
Old 07-18-2007, 03:26 PM
Hudson Hudson is offline
Old Mod
The 2.3L (OHV) engine in the Tempo is not related to the 2.3L (OHC) engine in Ranger...or any other 2.3L Ford-powered vehicle. The Tempo engine is related to the 3.3L L6 that was offered in various vehicles.
Old 07-19-2007, 09:00 AM
ParistsCP ParistsCP is offline
How hot is it where you live?
I had a Ford that used to overheat the fuel line and cause it to vapor lock in in the summer months. I installed a "racing" fuel pump. It was pretty loud, but it worked. For good measure, I put some heat shield stuff from the hot rod shop over the fuel line in the engine compartment. It never vapor locked on me again.
may or may not be your problem. Good luck with that-
Old 07-19-2007, 03:06 PM
socapots socapots is offline
did you do a pressure test on the fuel line to see if its getting the fuel there or not??
had that same type of problem wayy back with mine. ened up being something in the distributor that was the problem. got a new one and it was all good after that. cost a bit but still worth it.
