Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-17-2007, 10:15 PM
leroge leroge is offline
Cool Wrangler Fan Belt Squeel
Awful proud of myself! With the help of Automotiveforums.com, I replaced the water pump and serpentine fan belt on my 1993 4.0 L Jeep Wrangler! Likely saved about $200 here in Chicago! Tough get'n the fingers in and around that power steering device that hang's off the fan belt. Everything seems to work like a champ EXCEPT for the fan belt squeeling at engine startup. I assume this results from either too tight a fan belt since the belt certainly doesn't seem to be too loose. It wasn't clear how one sets the tensioning of the belt but I turned down the 'bolt' on the power steering housing until only minor 'deflection' of the belt resulted. As an effort to stop the squeeling, I sprayed some belt dressing and that seems to help but not an entire solution.
Any suggestions?
Old 07-18-2007, 11:27 AM
tomvid tomvid is offline
Re: Wrangler Fan Belt Squeel
Fan belt is too lose.
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
