Old 07-17-2007, 07:11 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
A/C presure High
Hey guys,
Got a problem.
My A/C does not blow cold air anymore. 2000 5.3. I went to Advanced Auto and bought the recharge kit. The directions says to put the hose on the lower preasure side, except there is no valve on the low preasure hose. So I put the dispenser over the only insertion valve I see while the engine was running just like the instructions wrote. But when I put the dispensor the gauge showed about 150 PSI (red zone), probably because it is the high preasure hose, and not to add feon but I had a more serious problem.. My question, what could it be? Where is the low preasure insertion valve?
Any ideas? I am not very familiar with A/C systems in general.
Thanks in advance
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 07-17-2007, 08:31 PM
rjeffery rjeffery is offline
Re: A/C presure High
Low pressure hose should be right below the high pressure hose. The connection on the recharge kit should only fit the LP side (bigger connection, covered w/dust cap). Did you have to force the connection on?
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 07-17-2007, 08:38 PM
The problem is that there are two ports what appears to be on the high pressure hose and no ports on the low pressure hose. The low pressure hose is the larger hose, correct?
I placed the can on the only port it would fit and that is what read the 150 PSI
Old 07-17-2007, 09:27 PM
abaird abaird is offline
For a 2000 truck to not blow any cold air I might assume there is a leak. Air in the system can cause high pressure. Having said that, I don't know if I would trust that gauge either. Look for any oily residue all around your ac lines and fittings.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 07-18-2007, 08:36 AM
Everything looks good as far as no oil residue.
Old 07-18-2007, 09:34 AM
taillight taillight is offline
It sounds like you have a leak. 1st you need R134A not freon. 2nd find the low side of your system. The low side valve is smaller than the high side. Start looking at the compressor. The high side has smaller hoses. The low side has larger hoses. Find the plastic cap on the low side (smaller fitting). Connect the R134A bottle to that side.
Old 07-18-2007, 09:36 AM
Like I mentioned before.. there is no cap for the low pressure hose, or at least I can not find it. The High pressure hose has 2 caps.
Old 07-18-2007, 09:58 AM
If the caps are right on top of the compressor the smaller one is the low side.
Old 07-18-2007, 11:01 AM
Jethro Jethro is offline
Send a message via AIM to Jethro
Silverado is right and I have the same setup in my 03 cheby. I am going to watch this thread incase someone with knowledge of recharging and the location of the lowside valve for these trucks. I was advised that that switch on the acumulator might be faulty. I get ac at first start and goes off occasionally just to be irritating. Almost ready to go to the stealer to get answers.
2002 LT Trailblazer 4x4 One of the first of this kind on the road
2003 3500 LT Silverado 4x4 ext cab
2006 Heritage Softail HD FLSTI
Old 07-18-2007, 03:20 PM
I will check the next 2000 I see.
Old 07-18-2007, 05:27 PM
Dano 00TA Dano 00TA is offline
As weird as it seems, you're right. I just checked my 00Silvy and it's the same setup? Low and High ports on the same line.
Old 07-18-2007, 06:29 PM
After reading this again today I had to run out and pop the hood on my 03. I could tell you everything about my 97 I used to have but I haven't hardly opened the hood on this one. The two fittings are on the same line but there is a junction in between them and what looks like a pinch in the line down from the low pressure fitting. That pinch is what holds the orifice tube which seperates low from high sides.
2009 Silverado 1500
2005 Yamaha GP1300R
Old 07-19-2007, 05:25 PM
This makes sence, Ill work 0on it tomorrow thanx
Old 07-19-2007, 05:38 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Pitch that wal mart death kit.
You need a recharge gauge set with the low and high side gauges to recharge and or check the system.
With compressor jumped and running post back you low and high side readings at idle and at 2K.
With a ac recharging gauge set.
Like one of these.http://www.ackits.com/merchant.mvc?S...erantGaugeSets
http://www.ackits.com/merchant.mvc?S...ory_Co de=DIY
Low side should be close to 30 lbs.
If it is dropping under 25 lbs the switch will cycle or shut off compressor.
Wal Mart DEATH KITS
You cannot properly and safely recharge an air condition system with them.
The one side stop and go gauge does not tell you what your system is doing or is over charged or undercharged.
A overcharged or malfunction air condition system can reach over 500 lbs of pressure.
Enough to blow up that can or system and freeze you at first and the burn you or blind you and if any propane /butane in there blow and light you up.
The stop leak crap and who knows what kind of oil in the kits there will stop your system for sure.
Just like pouring super glue in it.
And some kits even contain freon with a butane mixer.
Good for a big blast.
If you are going to do it do it right and safe.
Here is what you need to start with.
In the older days you could just throw in a can and go.
But over the years just adding freon is getting harder to do.
Newer systems have to have the correct amount of freon down to the ounces.
Most will need pumped down and vacuumed down and the right and amount of oil and a set amount freon charge installed to get the air to cool right and the system to last.
If an air condition is low there is usually a leak that needs fixed and also a lose of lubricating oil from system.
Also air and moisture enters a low system
If you are going to try to do it get the proper type air condition gauge set with the low and high side gauges.
Hook up the gauges and get a reading with compressor running at idle and at 2000 rpm on the high and low side.
Post back pressure reading and we can help you.
MT
MT
Old 07-20-2007, 10:16 AM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
Hey There, I hope you are having luck on your AC. I am a licensed AC tech in south texas, and I sympathize with you
I tried reading my silverado's ac pressure and was stumped. The design is such that, the pressure is dropped across the orifice tube. It acts like the expansion valve in older systems. I finally figured that out after scratching my head and swearing there is NO low side hose.
You definitely should flush, vacuum, and recharge that truck before things get worse. You are going to be shocked what you find on that orifice!! It is a filter that lies between those two fitting you found on the one hose (low and high side).
Good luck and let me know if you need any step by step on how to flush, vacuum, or recharge the system. I am a big fan of DIY. I use an old refrigerator motor to vacuum out all my systems and it has been working great for 5 years. I have fixed many a system with it.
Good Luck!
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
