Old 07-17-2007, 05:51 PM
bamadam bamadam is offline
Oil for new engine...
Had a Jasper 5.7 longblock installed in my 95 Silverado 4X4 awhile back and truck runs great.
Now it is time for my first oil change and I was wondering what oil/weight to go with since the garage/Jasper had no specific recommendations??
Old 07-17-2007, 06:51 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Oil for new engine...
Over 0 degrees outside tempt book calls for 10w30 engine oil.
First few K miles 5W30 will get in the tight places a little better
What weight did you use to start with?
MT
MT
Old 07-17-2007, 09:44 PM
abaird abaird is offline
Any quality name brand oil will do fine. Just make sure you change it on a regular basis. I use Mobil 1 synthetic and I would recommend it but it is kind of pricy. But depending on your driving habits you can extend your intervals with synthetic oil.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 07-17-2007, 09:59 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Same here. I bought a 2006 Chevy Uplander last Fall and when it came time for my first oil change I opted to also use Mobil 1. Even though it may cost more,( Although I noticed the other day at Wal Mart the price had gone down to $19.92 from $23.88 the previous time.)the longer interval change actually makes the initial cost lower. I plan to keep the oil in the engine between 7500 to 10,000 miles with a filter only change and "top off" halfway in between. Using synthetics in my opinion can help lower our consumption of oil and eventually our dependency , and it also is easier on the environment <steps off soapbox>.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 07-18-2007, 06:43 AM
MT
I don't know what they used, that was kind of the point.
Synthetics were mainly what I was asking about. Never used them before and was wondering.
Old 07-18-2007, 08:13 AM
daman daman is offline
Since that engine is new and tight a good full synthetic 5w30 is what i would
use, if consumption becomes a issue go to a 10w30, Mobil-1,Amsoil is what
i use, also use any filter but FRAM there garbage..
i use 5w30 synthetic in all my cars/truck and change it out a 5k
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 07-18-2007, 09:35 AM
taillight taillight is offline
I have rebuilding engines for 40 years. Start with synthetic and stay with synthetic.
Old 07-18-2007, 10:06 AM
MT-2500's Avatar
AF - Advisor
As said symthetic is one of the best oils for extra lube and cold weather starts and real hot weather lubercation.
Also on regular oil Diesel oil like shell rotella has more lube additives like zinc and other stuff that has been removed from regular gasoline engine oil because of newer epa regulations.
On gas engines that still have the old style cam and lifters the diesel oil will give a little better lubercation.
Only problem is geting it it the lighter weighs.
Good luck
MT
MT
Old 07-18-2007, 12:57 PM
Thanks for the advice folks.
First time I've ever heard anything bad about FRAM. Wassup??
Old 07-18-2007, 01:06 PM
MT-2500's Avatar
AF - Advisor
To put it plain Fam filters are junk.
Poor filtration elements.
And for the last 45 years Fram have gave poor oil pressure on GM engines.
And they are not getting any better.
AC Delco are low priced and good.
Wix and a few others major brands are good. to.
But anything is better than a Fram.
http://minimopar.knizefamily.net/oilfilters.html
and
http://www.motor-oil-engineers.com/M...eers%20PDF.pdf
opens a pdf with Firefox
MT
MT
Old 07-18-2007, 01:23 PM
Cut a FRAM open then say a WIX,AC,PureOne,M1, etc. just to name a few and
you'll see the difference,paper end caps and poor craftsmanship, there's more
too it but you get the idea..
Old 07-18-2007, 01:43 PM
MT check that link you mentioned . I clicked on it and got this,"Not Found
The requested URL /~yoderw/oilfi...lterstudy.htmlhttp://www.motor-oil-engineers.com/Motor Oil Engineers PDF.pdf was not found on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Otherwise I am very familiar with the first link that was mentioned and have even linked some of my other posts on this site to that study. If you did a search on this site you would see the issues with Fram filters. I exclusively use A C Delco filters in all my GM vehicles.
Old 07-18-2007, 04:04 PM
MT-2500's Avatar
AF - Advisor
97ventureowner
I recheked it and it only opens a pdf with Firefox for some reason.
explore goes haywire on that hit.
Sorry about that.
MT
MT
Old 07-18-2007, 06:52 PM
So a synthetic 10W-30 (live in AL) with a Mobil 1 filter would do th job??
Show of hands??
Old 07-18-2007, 07:59 PM
Yes!!! use the HM(high mileage),if your going with M1, you can get it at
wall-mart, all there 5qt jugs are 19xx a gal. great deal..
