Old 07-16-2007, 08:59 PM
(_S200_)'s Avatar
(_S200_) (_S200_) is offline
Cleaning off Scratch X
Hi everyone,
I have polished my model with Meguiars Scratch X and im satisfied with the shine. Only problem is there is some scratch x residue left on and I cant seam to get it off.
I was wondering whats the best way to clean the Scratch X off and not damage the model/paint
im using tamiya spray BTW.
Thanks!
Old 07-16-2007, 09:10 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: Cleaning off Scratch X
As in the panel lines and hard to reach places? If so using a tooth brush will work, or a tooth pick.
In Progress
Old 07-16-2007, 09:30 PM
(_S200_)'s Avatar
There is some in the panel lines, but what the particularly difficult stuff to get off is on the flat surfaces, generally were my polishing "circles" end as i polish in small circles on all panels.
i've tried with soap and warm water but to little effect.
looks like this
Thanks
Old 07-16-2007, 10:16 PM
rsxse240 rsxse240 is offline
That looks as though it is IN the paint. I'd try using just a bit more polish and buff it out a little at a time. Or you could try using some stuff I have found to work quite well, Novus plastic polishing products. I'd suggest the fine scratch remover followed by clean and shine. Or in your case, the clean and shine might work well by itself.
The problem with anything from McGuires is that it is designed for much harder thicker paints, so it basically softens the paint ever so slightly so it fills in scratches with paint.
Old 07-17-2007, 02:32 AM
(_S200_)'s Avatar
Thanks!
I'll have to try that stuff, I saw some of it at my LHS, i'll go by and pick some up in the morning
Thanks
Old 07-17-2007, 07:33 AM
Veyron's Avatar
Veyron Veyron is offline
I usually submerge the body in a bowl of mild soapy water for a few minutes so it can soften the compound residue, then I scrub it off with a babies toothbrush(soft bristles).
Old 07-17-2007, 08:51 AM
CADguy's Avatar
CADguy CADguy is offline
Meguiars wax or cleaner/polish will remove the residue also..
Matt
