Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 07-16-2007, 09:54 PM
-tion -tion is offline
Jetta Refrigerant Recharge: Please Help
Hello, I am new here. I just bought a 1996 Jetta GLS and learned the air conditioning isn't working. I suspect the owner never bothered to recharge the refrigerant but that it still works, because the car resided in a cool climate since 2001.
To test the theory, I bought a recharge kit and refrigerant, only to learn that I can't find the low pressure port. I do see two black caps attached to metal hoses in the engine compartment directly in front of the passenger side dashboard. Might one of these be the low pressure port?
I would really appreciate some direction, and possibly a photo, if it isn't too much to ask.
Thank you, Emily
Old 07-20-2007, 03:54 PM
Doug Tatham Doug Tatham is offline
Re: Jetta Refrigerant Recharge: Please Help
I'm only familiar with up to 92, but on that style there is a LP connection right in front of the compressor. Trace your lines, if it's after the condenser and before the compressor, it's low pressure. If it's after the compressor and before the thermal expansion valve (or evaporator) it's high pressure.
Old 07-20-2007, 03:59 PM
Thank you.
Old 07-23-2007, 11:26 PM
ctuagent117 ctuagent117 is offline
it will only fit on one side.
Old 08-12-2007, 02:47 AM
2001jettavr6 2001jettavr6 is offline
hes right it will only fit on one port, usually located closes to the hoses that lead to the firewall which is the heater core hoses
Old 08-12-2007, 11:20 PM
well, newer audis for example have them totally seperate places.
The safer way of remembering them is that you always fill in the smallest nipple..or was it the largest..uh oh
