Go Back   Automotive Forums .com Car Chat > Cadillac > Deville
Old 07-16-2007, 07:54 PM   #1
OleBones
1999 Deville Check Coolant Level Warning
The check coolant level on my 99 deville Northstar comes on frequently but the sytem is never low. Is there a coolant level sensor somewhere on this car? Also the temperature rises to about 222 at times, usally runs between 199-203. Could this be due to a clogged radiator, loose belt on water pump or worn water pump, bad thermostat?
The A/C just recently started acting funny too in that it doesn't get as cool and really warms up fast in stop and go driving, both the temperature of the engine and also the temperature from the A/C outlet. The pressure readings on the 134A says the system is fully charged. Both fans are running.
OleBones is offline   Reply With Quote
Old 07-16-2007, 10:10 PM   #2
caddydaddy
Re: 1999 Deville Check Coolant Level Warning
Yes, there is a coolant level sensor in the overflow tank. The coolant temps are normals, so no worries there. Have you changed the coolant recently? It's very important on the Northstar engines to have it changed every 2 years.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
caddydaddy is offline   Reply With Quote
