Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 07-16-2007, 06:35 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Ebtcm ???
what is the EBTCM on our 98 achieva ??
what part is it and what does it do ?
the dealer says it is bad on ours
the ABS and ETS off lights are on
the battery get drained down while it is running because something keeps frying the alternator
its a new problem
after the security system issue we finally fixed
help ??
what is an EBTCM ??
could it be fluid leak short in the circuit ?
if i were to check resistance of the wheel sensors with the digital multitmeter then what reading should i get if they are good ?
what else should i check and how ?
steering position sensor value ?
something shorts out the chargin system and fries the alternator, i have been thinking a screwed up relay ? relay in the EBTCM ??
pics ?
i tried to find one on car-part.com and it comes up as chassis control box(not engine) ABS(center of firewall)
is this it ??
or is that just the PCM ??
need to find out ASAP
where can i find out ??
thanks
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 07-17-2007, 01:37 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Ebtcm ???
Electronic brake and traction control module. It is the brain of the ABS braking and traction control system. Most likely located somewhere under the dash.
Also, the module controls the actuator for variable assist steering.
Timeslip 08/12/06
AF Community Guidelines
