Old 07-16-2007, 05:54 PM
ghink ghink is offline
Help, 97 Buick LaSabre water pump replace...
Water pump replace...
Can't figure out how to get to the bolt behind the power steering pully?
Old 07-16-2007, 06:34 PM
ChemMan ChemMan is offline
Re: Help, 97 Buick LaSabre water pump replace...
There should be a hole in the pulley. Rotate the power steering pump pulley to line it up.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 07-16-2007, 08:05 PM
It appears that the factory has installed the wrong power steeting pulley for none of the holes line up. BTW, I bought this car new.
The bolt head is at the outer edge of the pulley making impossible to remove.
So that being said, I have to pull the power steeing pump. How do I do this?
Old 07-17-2007, 08:14 AM
rustbucket rustbucket is offline
You have to loosen the powersteering pump from the block, and move it out of the way slightly. Line up the hole in the pulley with the power steering mounting bolts (2 of them), might need a mirror to see them through the hole.
Daily Driver: 2008 Chevy Impala - 30000 mi
Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre
Old 07-17-2007, 08:16 AM
Finally figured out that the holes in the power steering pump are to access the two bolts for the power steering mounting. Pulled these bolts drop the power steering down to access the bolt for the water pump.
Old 07-17-2007, 09:34 PM
Smith1000 Smith1000 is offline
Just replaced a water pump on my 97 Lesabre and went through the same. Kind of tricky to get the bolts restarted on the power steering pump. Too bad the pump has to come off just to get to that one bolt.
Old 07-18-2007, 05:33 AM
In deed it was tricky to restart the two bolts for the power steering. It took me 30 minutes to remount the power steering. Maybe one could just loosen the bottom bolt & remove the top one this would make it easier.
Old 07-18-2007, 05:51 AM
I know what you mean. I tried taking out the top bolt and leaving the bottom, but still didn't seem to gain enough clearance, so I continued to back off the bottom. Once one of the bolts is started, it goes back on quick. Sure glad to have the job completed.
Water pump went out in this heat and, fortunately, the engine did not get very hot. Last January, the idler pulley for the belt froze and the belt dropped off. Hopefully, these problems are solved for a while. It has 150,000 miles on it now. I have another 97 Lesabre with just under 180,000 miles on it.
Old 07-19-2007, 05:21 AM
One could remove the original bolts one at a time and insert longer bolts or bolt to hold the alignment. Then remove the water pump and install the new pump. Take the long bolts out one at time and then install the original bolts.
