Old 07-16-2007, 05:00 PM
alphalanos alphalanos is offline
Power supply fans not working.
I have an Antec 410w power supply. Recently I noticed neither of its two fans are working. My computer still runs. My 4 other case fans stopped working also, I switched theire power plugs from my power supply's fan only plug onto one of the normal power plugs and they all work. Should I get a new power supply? Its out of warranty.
96 EJ6. Future home of boosted B18C1.
Old 07-16-2007, 07:05 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Re: Power supply fans not working.
I'd say get a new one and one with a little more power like 550 or 600w. I'm using a 750w for now but will upgrade to a 1200w water cooled early next year with tax refund.
Old 07-16-2007, 09:00 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Not everybody needs a power plant in their tower. A 410w has plenty of juice for some people, depending on the setup. Anything above 700w is overkill for 98% of people. You would be a fool to go that high.
As per alphalanos, go ahead and get a new power supply. You shouldn't need anything above a 450w unless you plan on extensive upgrades.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-16-2007, 09:08 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 07-16-2007, 09:14 PM
Thanks. A little less money that I could have used on my Si down payment
Old 07-17-2007, 12:05 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
some powersupplies have on and off switches for the fans
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 07-17-2007, 09:12 PM
The reason I'm going to be getting a 1200w power supply is because I'm going to have a quad core cpu, dual 8800 ultra's, 4 1tb hdd's, and full liquid cooling system to cool everything which adds on an additional 10 fans to the 3 I have now. But for alpha around 450-500w would be sufficient as far as you worrying about price you can get a new one from tigerdirect.com for around 30 plus shipping.
Old 07-20-2007, 09:42 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Sounds like a whole lot of overkill to me.
Old 07-21-2007, 01:15 PM
Knifeblade Knifeblade is offline
Maybe overkill, but then there is the extra power for upgrades later, certainly dependent on the power 6-8 pin leads amounts.
I disagree, I don't think it's overkill!!!!!! Perhaps a bit excessive, but never overkill.
Think of this, if the OP hopes to drop in a new GPU, say 8800 Nvidea or ATI 2900, those bad boys need their own tap off the PSU and up to two power leads each, in OVER 350 watts to run them.
But, that's if the OP goes there. My point remains, he can if he chooses to with the upper PSU, otherwise he's stuck. And that goes for any other upgrades.
Old 07-23-2007, 01:22 PM
Polygon's Avatar
The Red Baron
I wasn't only referring to the PSU.
Old 07-24-2007, 02:11 AM
The fans? I agree, THAT is overkill.
Old 07-24-2007, 10:53 AM
Polygon's Avatar
The Red Baron
Yeah, the fans, and the rest of of the setup.
