Old 07-16-2007, 12:11 PM
Malicus Malicus is offline
fuel problem no start on 89 4.3
My 4.3 S-10 truck wont start. ran fin before although would fire later then usual since i had a fuel pump professionally installed. Maybe 200 miles ago. wont fire at all now. got it to fire with ether. fuel pump sounds good and I removed one end of filter to make sure fuel gets through. Took apart throttle body and fuel is there too but doesnt come out either injector. is there a module or something I should replace? any help is greatly appreciated. Not sure how to check codes. Dont have a reader
Old 07-16-2007, 02:37 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: fuel problem no start on 89 4.3
Check you fuse panel for a blowed fuse.
Will it start on a snort of carb cleaner?
Does it have spark to spark plugs?
MT
Old 07-16-2007, 06:06 PM
has spark as it fires with some ether
will try carb cleaner
checked fuses none blown but not sure if injector fuse under hood maybe
Old 07-17-2007, 07:23 AM
MT-2500's Avatar
AF - Advisor
Make sure you have fuel pressure.
Check injector 12 volt feed side.
Check for injector pulse with a injector test noid light.
MT
MT
