Old 07-16-2007, 09:58 AM
Boosted1 Boosted1 is offline
Horrible back/mis-firing...
Alright - I'm slowly getting the VR4 (93) back on the road - just shelled out $800 for tires. It's taking so long because I'm learning houses are just stupid expensive. Anyway - I haven't really driven it but free revving and on my street as soon as you go WOT it cuts out and won't rev further...just studders. I can slowly rev it up but as soon as I go WOT again, same thing. The exhaust sounds brutal with the engine cutting out. It's sad that my Mazda6 would walk it right now.
Here's the thing - it never did that until I had the engine "professionally" shampooed - and by shampooed I mean SOAKED. Then it started a bit and I replaced the wires. It helped somewhat but now it's pretty much undrivable. So...could it be something as simple as plugs (I have bosch platinum ready to replace), or do we think there's a hole somewhere? I HOPE it's a simple fix because my 6 is leased and I've put over half the allowable miles on it one year in (out of four) - so I need this car to work! I know some of you have experienced this - what was wrong wtih yours? Thanks in advance!!
1993 Mitsubishi 3000GT VR4 (STOCK)
1989 5.0L Ford Mustang (MODIFIED)
http://www.cardomain.com/memberpage/761789
Old 07-16-2007, 03:07 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
Re: Horrible back/mis-firing...
umm..i think if you read the car manual they dont recommend bosch plugs in the 3s cars..they recommend the NGK..thats all i run and works great! try the plugs..cheap fix..hope that will work..otherwise there could be many possibilities to what it is!! good luck
Old 07-16-2007, 03:23 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
yes jeff is right.. throw those POS plugs away and get factory plugs (or NGK)... I would get the cheep like 1.50 plug's that are just copper.. as they work great for our cars!
Old 07-18-2007, 02:27 PM
Well that was thirty bucks wasted. Oh well, I'll get the NGK's if they're worth it and see if that does anything. Thanks for the replies guys.
Old 07-19-2007, 08:57 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Definately go with the ngk plugs.. if its not those then you may have a loose vacume line somewhere, that was the issues on my 240sx when it was having similar symptoms.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
