Old 11-06-2002, 04:16 AM
worrdogg worrdogg is offline
Exclamation B16A Headers
Which headers will fit a B16A?
Old 11-06-2002, 01:42 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
to be safe, order the header for a 95 Del Sol VTEC or a 99 Civic Si. If you are talking about a JDM 1st gen B16A, then you have to deal with the fact that an after market header is probably only going to have 1 O2 sensor bung....and with a NON-OBD B16A, you need two bungs. i do believe that teh An-R header gives you the option of getting 2 bungs. not sure about other companies tho
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 11-07-2002, 12:41 AM
teg2nd teg2nd is offline
If you are using 1st gen B16 , there are not that many choeses. The O2 sensors must be placed in the right spots. Use copy and paste to chek it out why: http://www.hondata.com/techo2problem.html
You can't use 4-1 headers if you don't wont any lean conditions. If you can find the right 4-2-1 header, you'll need to cut holes in it for O2 sensors(no more warenty)
You can convert to OBD1 setup, you'll need OBD0-OBD1 adapter,OBD1 distributor and OBD1 ECU.
My setup is: 90integra(OBD0), 2nd gen JDM B16a(it's OBD1), DC 4-1 header. I'm using 1 O2 sensor(4wires)
:toothless
99 DX header + test pipe sentoyang '96-'00 Civic 1 10-26-2009 02:34 PM
cali spec headers?? AHHKILLA Eclipse 2000+ 0 04-28-2009 12:03 AM
b16a headers jt_crx '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-03-2004 11:38 PM
B16A header for CRX Mojoe '88 - '91 Civic | CRX | Wagon | Shuttlee 5 11-22-2003 05:50 PM
B16A Header CanuckCRX Engineering/ Technical 5 12-20-2002 10:43 AM
