Old 07-15-2007, 11:19 PM
georgelovesdirt georgelovesdirt is offline
Trans swap checklist
I need the trans, the converter, a lot of trans fluid, new gasket, sockets, two extensions, torque wrench, new rear main seal (I’m going to do that wile I’m at it, should i get a lightweight flywheel?) lock tight (what type and how much?), trans jack, normal jack for the engine, am I missing anything?
I was considering having my trans builder put a slightly higher gear ratio in it for better gas mileage, is this a good idea? what specific gear kit should I request?
Old 07-16-2007, 06:08 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Trans swap checklist
If you are changing transmission always be sure to flush out the rad transmission cooler.
A good transmission jack and safety stands to put under it and a real big or bigger drain pan to catch that old fluid and some cat litter to take of what you do not catch sure does help.
http://www.automotiveforums.com/vbul...d.php?t=726976
second post.
MT
Old 07-22-2007, 04:17 PM
silverblazer silverblazer is offline
I found that if you just invest in a good 3ft extention it comes in handy with a wobbly head to reach the top bolts
1995 Chevrolet Blazer LT
4x4 Red and Silver
CHEVYS RULE
