Old 07-15-2007, 11:11 PM
aznboi_2 aznboi_2 is offline
1990 civic won't start
okay i bought the car with a no start situation this past summer. I changed out the whole dist and the car started over. i let the car sit for the winter and nvr turn it on until now. the car would start and then die out. im not sure what it is. I changed out the alternator and the rotor in the the dist cuz it was bad. I checked the fuel lines and there is fuel coming out and of course theres spark. i try hold the throttle open to but it will only run for a little bit and die out. help me out here
Old 07-15-2007, 11:23 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: 1990 civic won't start
grounds??
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 07-15-2007, 11:32 PM
i checked all the grounds. they are all there and like i said the car started before during winter and the just sat until now.
Old 07-16-2007, 12:27 AM
ATMDC's Avatar
ATMDC ATMDC is offline
old gas from sitting for a year?
Old 07-16-2007, 11:29 PM
viper-blue's Avatar
viper-blue viper-blue is offline
could be you put the distributor in wrong. It may have been willing to start before the winter time, but if your timing isn't just right it may start under certain temperatures and not others. It could be way installed the wrong way, or maybe off by 10 degrees or so
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 07-17-2007, 12:49 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Im going with bad gas first lol.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-23-2007, 01:22 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
umm... I'm confused... 90 Civic should be a D series motor... D series motor, all the dizzy's are interchangeable, with the exception of putting a DPFI diz on a MPFI motor... you can't do that w/o adding a sensor... CPS I believe... but the diz casing and housing are indeed the same... internal parts are all the same, and from what I remember, you can only install the diz backwards if you really ram it in there, and you CAN'T put it in 10* off... the only timing that could be 10* off would be the cam... and changing the diz won't affect the cam timing at all...
Yep, I'd say bad gas too. Give it some beano, and fill the tank back up.
