Old 07-15-2007, 07:42 PM
mcetmc mcetmc is offline
Exclamation Spare Tire Suggestion
To assure that you can lower and raise the spare tire on your Caravan when you need to, I suggest that every few years you lubricate and exercise the mechanism every few years.
I just bought a 1997 Caravan and tried to lower the spare tire. The lower/raise bolt turned a few turns then began to ratchet; I assumed due to rust. I sprayed “Liquid Wrench” into the space around the bolt. That freed it so that I could lower the tire the full distance.
To lubricate the mechanism, I mixed grease and gasoline to make a thin liquid and poured that into the space around the bolt. Lastly, I cranked the bolt full down and full up a couple of times to spread the grease around.
Old 07-16-2007, 10:20 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Spare Tire Suggestion
Good idea. It's one of those out of sight out of mind situations for most of us.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
