Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 07-15-2007, 08:07 PM
hdwnkr53 hdwnkr53 is offline
Cool 2006 Sonata high mount brake light
Does anyone know how to get to the high mount brake light bulb to replace it.I looked in the trunk and also tried to remove the cover from the inside to no avail,Thanks
Old 09-06-2007, 08:50 PM
robertfink robertfink is offline
Re: 2006 Sonata high mount brake light
The high mount stop light is a LED array. It is mounted to the rear deck panel. Remove that and you have access to the screws that hold it to the panel.
The rear tail light bulb replacement requires you to remove the lens from the car to get access to the sockets.
Robertfink
Speeed>>>> Guy
Logo Design Services
Old 09-14-2007, 05:15 PM
LesGrandsPieds LesGrandsPieds is offline
that's incorrect. The 06' and 07' Sonatas switched back to a single incandescent third tail light. If they were LED, chances are it wouldn't need replacement.
Old 06-26-2008, 10:53 AM
t-lude t-lude is offline
theres 2 screws that hold the light assy on the rear deck you can get to them from inside the trunk but one of the holes is covered with a sticker
then you can pull the assy out from inside the car.
Old 04-09-2009, 02:50 PM
smily_70 smily_70 is offline
they told me at the dealer you have to remove the rear deck to get to the screws..
that hold the light in place..if there are just two screws to remove in the truck.
how do i find them????????....
