Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-15-2007, 07:29 PM
chris90 chris90 is offline
very weird fuel pressure problem
94 camaro 3.4; fuel pressure rises to about 20 psi when key is turned, but falls quickly back to 0 psi. If timed right, I can get it started and it idles fine at about 20 psi. As soon as I give it gas, it stumbles; yet if I give it gas slowly, I can cruze down the road at 75 mph with no problem(cept if I gas it suddenly, then it hesitates.) Oh, and the fuel pump and pressure regulator were replaced 2 months ago. wtf. any ideas? would leaky injectors be the problem?
Old 07-15-2007, 08:27 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: very weird fuel pressure problem
sounds like a junk pump to me
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
was the fuel filter replaced when the pump was?
Old 07-15-2007, 08:41 PM
filter was also replaced...don't think its the pump cause it primes fine, system just won't hold pressure when primed, but will hold at 20psi when running. ( figured out how to get it started watching the pressure gauge; before it falls back to 0psi).
Old 07-15-2007, 10:33 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
how about something like a fuel-pump-relay? like a fuse.. the auto resets. maybe when it hits ~20psi the fuel pump overloads, causing the fuse to trip..thats why when you hit the acc hard, it causes the fuel pump to load again.
try switch that.. it COULD be the prob, makes sense to me..
how abt neone else?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 07-16-2007, 04:30 AM
Morley Morley is offline
Then either you were sold a pump without an internal check valve or the one in the pump is shot already. If it went bad that quickly then I would question weather the pump itself was junk.
Old 07-16-2007, 09:30 PM
wow...finally got it fixed. It was the rubber hose on the pump(in the tank)had come loose at the clamp and wasn't holding the pressure. After I pulled the fuel rail and injectors I primed the system and they didn't leak a drop. A lot of work for a simple problem...but isn't that the way it usually goes.lol
