Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-15-2007, 02:40 PM
joshuaozanich joshuaozanich is offline
suspension
I got a 91 caprice that im working on and i was wondering if i get oversized springs and shocks if i could put 26s on it. if anyone has a answer i would appreciate it thanks
Old 07-15-2007, 02:53 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: suspension
No. It takes WAY more than that, plus you will throw out the geometry of your suspension by doing so. In order for the 26's to even work, you will have to run tires with a sidewall height of 1" - can you say 10 series tires? They don't make such a thing. The car was not designed for tires larger than 28" overall. Especially on the '91 and '92 which have the rear tire body overhang.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-15-2007, 02:54 PM
Re: suspension
whats the biggest i can go as far as rim size
Old 07-15-2007, 02:55 PM
Re: suspension
whats the biggest rim i can go then
Old 07-15-2007, 05:29 PM
silicon212's Avatar
Confoundingly Lucid
Re: suspension
I would probably say in the 20" range - 22" if you do some work on it. Just remember though that by adding rims this big (and correspondingly small tires), you're going to kill the ride.
Old 07-15-2007, 06:56 PM
GreyGoose006 GreyGoose006 is offline
Re: suspension
and the suspension parts that werent designed to take that much stress
Old 07-19-2007, 09:50 PM
94HeavyChevy 94HeavyChevy is offline
Re: suspension
www.streettrends.com sells a complete 4 inch lift kit along with many other cool items...check it out...here is the link for the lift kit
http://www.streettrendsinc.com/Merch...uct_Code=15318
Old 07-28-2007, 12:16 AM
jrocapriceryder jrocapriceryder is offline
Re: suspension
Shyt They Sell A Lift Kit On Universalcarlifts.com That Clear 30'z M3 N My Homiez All Got Them....if U Wanna Ride High Go There If Not...... Or Try Bigboikits.com Or Kingkonglifts.com
