Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 11-06-2002, 12:12 AM
MrLocken MrLocken is offline
Send a message via AIM to MrLocken
320i Dancing Gas Gauge
I just purchased a 1983 320i in pretty much mint condition with 32,000 original miles on it. Sadly it has an automatic trans but at $1800 I could not pass it up! One of the few problems with the car is the gas guage...it either reads empty or it's dancing around the 1/2 tank mark....even with a full tank. Is this a known problem in this model? Any help would be appreciated...I hate not knowing how much fuel I have!
Old 07-06-2004, 01:21 AM
mmatsumotosr75 mmatsumotosr75 is offline
Smile Mine Too...
Hey There!
You know what man, mine does the same thing!!! I don't exactly know the cause, but i'm thinking it has something to do with the gauge itself. I smack the top of the dashboard and most of the time it goes where it should... Weird!
Old 07-06-2004, 01:22 AM
Re: 320i Dancing Gas Gauge
Hey it's me again...
By the way, I have an 1981 320i 5 speed. Different, but identical problems.
Old 07-06-2004, 07:10 AM
jeffreyb4me jeffreyb4me is offline
check the two small nuts on the back of the cluster. ones for the fuel gauge, the other's for the temp gauge. they loosen up or fall off and will cause these symptoms...................................jb.
Old 07-12-2004, 02:26 PM
Bimmer9 Bimmer9 is offline
jeff, what cluster are you talking about here? where is it found? My 318i 1991 has been doing that for both, the temp and fuel, but it goes away after a while, but I will rather get it fix. thanks
Old 02-15-2005, 11:57 PM
moefuggar moefuggar is offline
Re: Re: 320i Dancing Gas Gauge
I'm about to try your fix, fuel and temp are eradic on my 81 320i, I recently bought it with 79k miles on it and my odometer just quit a few days ago right at about 80k, and am going to pull the cluster to replace the gear. Did you encounter any problems pulling the steering wheel? I guess the center BMW emblem needs to be pried out for access to the nut. What about the 4 horn buttons on the wheel itself, come across any problem with them when the wheel is pulled?
Thanks
Help gas gauge does not work right and is not taking gas well!!! spflick Taurus | Taurus Wagon 9 08-05-2007 02:21 PM
temp gauge and gas gauge shaolyn '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-18-2005 02:59 PM
DIC gas gauge,speedometer, temp gauges not working hotep Aurora 7 05-09-2005 10:26 AM
Gas gauge stuck & no amp gauge makailaann Ram Pickup | Ram SRT10 1 05-09-2005 08:35 AM
gas gauge is stuck half way with full tank of gas jerom 3 Series 3 07-14-2003 07:50 PM
