Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 07-14-2007, 11:09 PM
jrthom jrthom is offline
2005 Sonata A/C Won't Work w/Remote Starter
I have a 2005 Hyundai Sonata and put a remote starter on it a couple of months ago. However, the A/C won't start (after the enginer is running using the remote starter) until the ignition key is turned. Looks like I need to bypass the accessories contact on the ignition switch. Anyone know how to do this? I can't find the wiring diagram for my car. Thanks.
Old 08-01-2007, 09:26 PM
gquinn gquinn is offline
Re: 2005 Sonata A/C Won't Work w/Remote Starter
The remote start needs to do exactly like the ignition switch does when it is used. All wires that power up need to be powered up. If the wire probed loses power in the crank cycle it should do the same when the remote start cranks or it can cause problems.
