Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 07-14-2007, 09:55 PM
TheSun95 TheSun95 is offline
Cruise Control not working
I have a 95 Del Sol Si, 1.6 sohc vtec and the cruise control won't come on. Is there a fuse somewhere for this thing. I don't see it listed in the fuse box unless Honda calls it something different. For anyone else with this problem I had it happen before and it was the little plastic stopper on the clutch and brake pedals that broke off and didn't keep the sensor button depressed but that's not it this time.
Thanx Scott
Old 07-14-2007, 10:00 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Cruise Control not working
Try putting your car in neutral and starting it with the clutch OUT. If it still starts it's a wiring or bad switch problem with the clutch.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 07-16-2007, 04:56 PM
Thanx alot for the reply. That test didn't do it but I like the way you think.
Do you know anything of a fuse for the cruise control ?
A few months ago it was the stopper for the switch under the brake pedal but I have since replaced it and it was working.
I will check when it gets dark tonight to see if the light on the cruise switch even lights up.
Old 07-16-2007, 10:39 PM
The switch on the dash for the cruise control doesn't light up; The switch for the fog lights doesn't light up either although they are working ?
Old 07-16-2007, 10:54 PM
NA is Best!
Yeah I believe there's a fuse under the dash for it. Check that.
Old 09-23-2007, 03:48 AM
oceansurfgirl21 oceansurfgirl21 is offline
Cool Re: Cruise Control not working
I am having this same problem but dont have the fuse box list under the dash... Did you ever figure it out??? Please let me know. Thanks, Bethany
Old 09-25-2007, 09:50 PM
No, I still don't have it working. There is no fuse listed for it under the dash nor in the engine compartment. The only other options I can think of is the sending unit, the vacuum or the actual switch. Did you check the stoppers under the brake and clutch pedals ?
